You wont be able to jog it without the controller. You most likely wont be able to drip feed it easily either though it has been done. It is a great machine and will be a relatively straightforward conversion.
There is a DM 3000 for auction near me but it looks like the control panel is missing.
Does anyone know if the machine can be moved under power without the controller or if there will need to be a full overhaul of the electronics to feed it code without the controller.
I'm hoping to go check it out this afternoon if I hear back from them and the auction ends Monday.
Any info is greatly appreciated!!!!!!!
Thanks,
Andrew
A lazy man does it twice.
Well........ I won the auction!
@fastest1
Do you have a link to wiring schematics for the DM 3000? I'm thinking of using a MASSO controller on it. not sure if I will replace the motors\drivers yet. Also need to figure out the tool changer.......
Thanks,
Andrew
I believe I do have the manuals and schematics somewhere.
Regarding the tool changer. I have the tool change macro that allows the turret to pivot 1 direction 60+ degrees and then backs up against the pawl. The macro works great however the changer I believe is designed to be bidirectional. The pawl is electromagnetically controlled (or can be for bidirectional use, but I havent seen anybody do it).
In my latest iteration, I do have a relay and power supply for that circuit to be operable. It will be just a matter of changing the macro to A. Lift the pawl, then rotate the shortest distance to the desired tool. There are some sensors in the changer itself that I think allow for tool position or number verification. Again I have seen no one use those sensors and you dont necessarily need to.
Also look into the Centroid Acorn.
Any info you can dig up would help!
I did plug the lathe in this morning and was able to get the spindle, light and coolant pump to power on
That is about as much as I can do with out the controller!
Andrew
Here are the schematics I had.
