- how can be more convenient and high efficiency for milling drilling CNC
Appliction
For milling and grinding process, CNC or FMS centre, heavy duty cutting, lathe, mold grinding,turning machine,metal cutting process
Feature
Pole size:50 x 50
380kgf for each pole
Magnetic field depth:10mm
5-sided machining is possible in one clamp
Key words
Magnetic workholding /magnetic clamping/electro permanent magnetic chuck/workpiece/magnetic tools /holding force/clamping force/magnetic plate/Machine Tool Accessories/CE certification/connector cable/electro plug/control master
- You may not post replies
- You may not edit your posts
Forum Rules
