Lagunmatic 250 help
Results 1 to 7 of 7
Thread: Lagunmatic 250 help
    Member Ws3's Avatar
    May 2020
    Default Lagunmatic 250 help
    I have a new to me Lagunmatic 250 with an upgraded m400 Centroid CNC system. I just bought it and it didn't have a draw bar. I had a 5/8-11 threaded rod that I tried, but I am not sure if it fits or if it takes 7/16. The guy who had it before me had it in a wood shop and did some wood working with it and the drawbar hole has sawdust in it. I am not sure how much as I could be screwing the 5/8 rod into the sawdust or the tool holder end. Maybe that's why I can't unseat the tool holder, the sawdust absorbs the impact?I tried hitting the end of the threaded rod to take out the tool holder, but it wouldn't pop out. I just want to make sure it is a taper fit and not some weird auto draw bar that I can't see. Any help would be appreciated. Also if anybody has the draw bar dimensions, that would be a huge help.Thanks
    Member machinehop5's Avatar
    Aug 2009
    Default Re: Lagunmatic 250 help
    ...use some PVC tubing (water pipe) to vacuum out the quill/draw bar bore...... is this machine 40 Taper (NMTB) type holders? It is possible the tool holder is bolted on to the face of the quill I, think 4places for a one tool operation Shell Mill or insert tool holder.
    DJ
    Member Ws3's Avatar
    May 2020
    Quote Originally Posted by machinehop5 View Post
    DJ
    Thanks for the reply. I didn't even think of using PVC, sometimes I over think stuff when the answer is so easy. I will give it a go when I get home from work. Every thing I have read said it is a 40 taper, but there are no drive dogs so it would likely would not be an NMTB but I did read it is probably a CAT40. It could be bolted. I am at work and don't have pics, but let me try to describe it. The lower part of the spindle that actually tightens the collet (collar?) is hex, above that is another type of collar with grooves cut for a spanner wrench and it has 3 Allen screws in it. I assumed the grooves for the spanner were to hold the spindle while you loosened the collet to change tools as I don't see a spindle brake, but the 3 Allen screws makes me think they are set screws and you can unscrew the top collar. But this is all speculation as the mill didn't come with a manual and I can't find one online.
    Aug 2009
    ...sounds like an Erickson QC type (aka Quick Change) They were common and should be available at good prices. also, to remove tool use a spanner wrench or caveman it with Punch and turn the Nut to break loose, then turn nut by hand clockwise until hand tight, then use the spanner wrench again to pop out the Tool.
    Member Ws3's Avatar
    May 2020
    I found this picture online, it's not very good, but you can see the upper collar with the spanner grooves and the hex screws.
    Attached Thumbnails Attached Thumbnails Lagunmatic 250 help-image001-png
    Member Ws3's Avatar
    May 2020
    Yes!!! Thank you so much. It's frustrating when you don't know enough to even know what to Google. It would have taken me weeks to find it. I found a pic based on your info and it helps me understand how it works. You saved me a lot of grief
    Attached Thumbnails Attached Thumbnails Lagunmatic 250 help-screenshot_20230822-083931-jpg
  7. #7
    Aug 2009
    ...Bingo. we have a winner. Kwit-Switch 300 was the name I could not remember......There were other types/brands too back then, so you may want to double check which tool holder type you have ..
    https://www.ebay.com/itm/13457563974...Bk9SR5667OzDYg
    Lagunmatic 250 help-s-l1600-jpg
Lagunmatic 250 help
Lagunmatic 250 help
