machine looses position in X axes
Results 1 to 2 of 2
Thread: machine looses position in X axes
    Member cncnut1954's Avatar
    May 2021
    Default machine looses position in X axes
    hi i am new to this forum
    was hoping to get some help with my older MS CNC JR vertical milling machine
    the machine loses tracking ever so often in the x axes
    totally random so is the amount of of position loss
    the amount is anywhere from .002 to .0049"
    it usually happens on the beginning of the milling cycle or end never in the process
    any help would be greatly appreciated
    DS
    Member awerby's Avatar
    Apr 2004
    Default Re: machine looses position in X axes
    It sounds like lost steps, which happens when steppers try to go too hard or too fast. You might try turning down the acceleration on the axis that's failing. It could be due to a lubrication failure, or it could be a coupler that's slipping.
