- Will it manage?
Will it manage?
Hello all,
I want to buy a 3040 chinese cnc to cut 10mm aluminium to rim hub rings. Is it possible with this macine?
Re: Will it manage?
It's possible but not particularly practical. As I understand it, to mill aluminum you will have to at a minimum modify the machine so it's a bit more capable.
Re: Will it manage?
The short answer is no, 3040 is not adequate for cutting 10mm aluminum.
It is _technically_ possible, if you don't mind spending several hours spraying WD-40 and listening to loud screeching noises. That's just to make one part. And the part will have lousy finish and wide tolerances. And the "spindle" - I use this term loosely - will be trashed before you complete one set of rings.
- Will it manage?
- You may not post replies
- You may not edit your posts
Forum Rules
