Tool height check, grounding through spindle bearings
Results 1 to 4 of 4
Thread: Tool height check, grounding through spindle bearings
    Nov 2007
    canada
    Default Tool height check, grounding through spindle bearings
    I purchased a tool height contact unit for my router and it requires either an alligator clip on the tool or ground through the bearings of the spindle. Since I want this to be an automatic operation at the beginning of each program I prefer the later. Anyone know of any problems running the 5v signal through the spindle bearings? is this the industry standard? thanks
    Member mactec54's Avatar
    Jan 2005
    Default Re: Tool height check, grounding through spindle bearings
    Quote Originally Posted by lgr View Post
    It most likely won't be very reliable, it is best to add a Brush, to run on the spindle up at the top is the best place, this is also a good idea to get a longer life from your Bearings, something like this can be quite small
    Attached Thumbnails Attached Thumbnails Tool height check, grounding through spindle bearings-baldor-rotor-grounding-png
    Mactec54
    Member SignTorch's Avatar
    Jan 2011
    the 5V doesn't flow through the bearings - the bearings (or alligator clip) are always grounded - the tool setter is an open contact which floats at 5V by way of a weak pullup resistor - when the grounded spindle makes contact - the tool setter contact becomes grounded - during which time 5V flows through the pullup resistor - works reliably in my experience -
    in some tools the bearings may be mounted in a plastic housing or rubber boot (insulated from ground) - in that case you could improvise some sort of reliable connection from the outer bearing case to ground (same effect as using a grounded alligator clip)
    www.signtorch.com
    Jan 2008
    Ca
    I'm trying to do just this, but its not working.
    It worked GREAT on my old Bosch Colt. Now I want to implement it on my new 600w spindle.
    I've got the parts made up, and thinking it would be a straight plug and play, it's not.
    Seems like it is electrically interfering (shorting out) with the other electronics.
    I have no resister in line, and honestly, not sure of the polarity (Going to double check tonight)
    But if I can get this working. its a supper set up!
    I have some pictures, but can't seem to get them uploaded.
    I'll try uploading them again later(might be a work computer thing)
    My Build: http://www.cnczone.com/forums/diy-cnc_router_table_machines/113711-my_build_-_many_thanks.html
