Problem Manual Tool Change - Dolphin CAM doesn't seem to follow settings
Results 1 to 3 of 3
Thread: Manual Tool Change - Dolphin CAM doesn't seem to follow settings
    Default Manual Tool Change - Dolphin CAM doesn't seem to follow settings
    Hi
    I'm having issues with getting the Z height to follow the settings I've entered in the "Tool Change" dialog box with Partmaster 15 and Mach4.
    It seems that whatever I enter in the "Tool Change" settings it doesn't seem to be followed and the Z axis does not allow enough clearance to change the tool.
    This is a manual change situation.
    Any help would be appreciated.
    Phil
    Feb 2007
    UK
    Default Re: Manual Tool Change - Dolphin CAM doesn't seem to follow settings
    Hello Phil,
    Could you send me the PartMaster CNC file file and tell me which post you are using ?
    Some posts have "hardwired" values
    andre@ dolphincadcam.com
    regards
    Andre
    Feb 2007
    UK
    For the benefit of the forum, here is the reply to this question ......
    The post is using the CLEARPLANE to position the tool if the tool is not already at the Toolchange position…
    if ( $Z ne $ZTLOAD ) then
    #N " " (_G00) (_G28) $ZTLOAD:ZAXIS eob
    #N " " (_G49) EOB
    Endif
    #N " " (_G49) eob
    #N " " $TOOLNO:TOOL (_M06) " ( " $JOBTEXT " )" eob
    #N " " (_G00) (_G43) $CLEARP:ZAXIS $TLCNO:TLC eob
    So you can either modify the post ….. #N " " (_G00) (_G43) $ZTLOAD:ZAXIS $TLCNO:TLC eob
    Or set the Clearplane to the required value ….
    regards
    Andre
