need some easy lathe CAM help
Results 1 to 5 of 5
Thread: need some easy lathe CAM help
    Member turbothis's Avatar
    Oct 2009
    usa/oregon
    Default need some easy lathe CAM help
    for some reason i cant get the cutter to go into the under cut area or the face at all
    i try it checked and unchecked with no change
    i look at the door knob example and my settings are the same and it does the under cutting and face?
    sharnoa SD-900 kflop/kanalog W/centroid DC servos
    enshu VMC 400 kflop/kanalog W/FANUC DC servos
    Oct 2009
    usa/oregon
    Default Re: need some easy lathe CAM help
    door knob example
    Feb 2007
    UK
    Hello,
    Please send me the .cnc file
    andre@dolphincadcam.com
    ATb
    Andre
    Oct 2009
    usa/oregon
    email and file sent. thanks
    Feb 2007
    UK
    Hello Just for the sake of the forum, the problem was with the XZ extents used in the command
    Making the sizes bigger solved the problem.
    ATb
    andre
