Hello,
I'll look into it.
Andre
Need help with why it will not let me single block my tool path when I run the simulation. It is just a profile cut. PartMaster Milling & Turning V14.6.2017.3
I am not using the 3d simulation just the normal run in the lathe module.
Thanks, machineitright
Hello,
I'll look into it.
Andre
Thanks Andre,
Do you need my file?
- - - Updated - - -
Thanks Andre,
Hello,
sorry for the delay in getting back to you, I overlooked this.
Single step will just show a single operation not the whole program, so this is working as expected.
To see the individual moves you need to use Pause mode, then hit Run and then from the right hand status panel you will see a flashing red button, click this to see each move.
Click Stop to reset back to normal run mode.
ATb
Andre
Oops !
One thing I forgot to mention is the for Pause to work – the tool view must be set to Animate or Envelope
