Why is only one contour smaller?
Results 1 to 3 of 3
Thread: Why is only one contour smaller?
    Aug 2008
    Default Why is only one contour smaller?
    First time machining a part, and for some odd reason only one contour machined smaller, whereas everything else machined right on size.
    The 2 1/2" diameter hole came out .080 smaller (2.420")
    I have no clue if it's a glitch in the post processor or something I did.
    The .DXF drawing was done with OnShape, and the G-code generated with Dolphin CAD/CAM ( my first time using the CAM part)
    I've enclosed the original drawing, as well as the first lines of the .TAP file because the 2 1/2" hole is the first to be cut ( I couldn't post the whole program)
    Edit; I notice it's difficult to see the writing in the second picture, but line 25 looks like this;
    N25X-1.085I-1.0075J0.0
    I'm no G-code expert, but to me, that " X-1.085 " seems to be the issue. ( 2 times 1.085 plust my .250" diameter cutter equals 4.20 )
    Shouldn't that be X-1.125" ??
    Thanks for any help.
    Dan
    Attached Thumbnails Attached Thumbnails Why is only one contour smaller?-test-piece-drawing-jpg   Why is only one contour smaller?-test-piece-drawing-b-jpg
    The one that dies with the most tools, WINS !
    Feb 2007
    UK
    Default Re: Why is only one contour smaller?
    Hello Dan,
    I think this is something to do with an approach move or arc splitting.
    Please send an email to support@dolphincadcam.com and attach the .cnc please and I'll take a look.
    Regards
    Andre
    Aug 2008
    Thank-you Andre !
