Hello,
If you let me know which one of the Centroid posts you are using I will get it fixed.
On a more general note. Please use these contact details info@dolphincadcam.com
ATB
Andre
I am using V14. The Centroid PP (milling) that was supplied doesn't put in any M8/M9 codes when requested. Is there a way to get a Centroid PP that will utilize cooling M-codes (M8/M9)? I emailed Dolphin-USA but it has fallen on deaf ears.
Hello,
ATB
Andre
Thank you Andre. There was only one Centroid PP. It should be attached. replace the .doc extension with .ppr.
