Need Help! Dolpin Partmaster v14 cad cam 2d array or pattern
Results 1 to 3 of 3
Thread: Dolpin Partmaster v14 cad cam 2d array or pattern
    Feb 2016
    Default Dolpin Partmaster v14 cad cam 2d array or pattern
    I have a project requiring manufacturing identical parts. I have the contours and points done. But how can I array/pattern them so I can have them nested on a single material and machine 50 at a time?
    Feb 2007
    UK
    Default Re: Dolpin Partmaster v14 cad cam 2d array or pattern
    Hello,
    You need to use the miscellaneous command Repeat to create this.
    The general format is :--
    Repeat on - set XY offsets or rotations etc
    Select tool #1
    Goround Con1, left ..... etc
    Goround Con2, right .... etc
    Repeat off
    Repeat on - set XY etc
    Select tool #2
    Drill Pat1
    Repeat off
    Using this method, all the Contours would be machined and then all the holes drilled.
    If you need to machine all featues in the first location and then repeat them, use this method
    Repeat on ..... set XY etc
    Select tool #1
    Goround Con1.....
    Goround Con2 ....
    Select tool #2
    Drill Pat1 .....
    Repeat off.
    Please not that you will no see the toolpaths until you have used the repeat off command and then Run the program.
    ATB
    Andre
    Feb 2016
    Oh OK I see now... TX very much! I was able to do what I was wanting in the 3d Cam with the pattern function. I will go back and redo in the 2d Cad just to learn it better. TX
