Re: Bridgeport EZ path lathe data sending software
Moto,
Exit EZPath program by select 'Utils'. It should switch to a screen that gives several comm options: Z-modem, text, EZlink. Need one of these programs to talk to the EZPath. Good luck finding them, and they only run on MS-DOS 6.22.
Regardless, RS-232 comm may or may not work on EZPath, it depends upon the software version and the pc-motherboard. if the motherboard was upgraded/replaced from the original it probably will not work, the software is incompatible.
FYI, I worked in Bridgeport / CMS in early 90s and wrote the communication utility software. After '96 it was never updated by CMS to be compatible with pc-motherboard replacements.
