Newbie Need help with Fanuc 6M DNC parameters
Results 1 to 5 of 5
Thread: Need help with Fanuc 6M DNC parameters
    Member samysnes's Avatar
    Dec 2020
    Question Need help with Fanuc 6M DNC parameters
    Hello all!
    I am new to the site and also new to CNC controllers, DNC and everything around it. I have spent an entire weekend educating myself and trying to wrap my head around the whole thing out of necessity (emergency at work).
    I think I finally have a good grasp on what I'm doing. We use a Fanuc 6M controller for an Amada Coma 567 turret punch.
    I know that parameter 340 and 341 determine the I/O device to be used. In my case 340 and 341 are set to 3 which would use I/O device #3 (RS232) with settings controlled by parameter 312 . Not sure why device #2 / parameter 311 is so often recommended, they seem identical in the maintenance manual. My 312 parameter is set as follows:
    [0][0][1][1] [1001]
    Which I determined would mean (left to right):
    No tape feed
    N/A (unused bit)
    Control codes not used
    Stop bit = 2
    Baud rate = 4800
    The only thing I don't understand is the whole Xon/Xoff DC1/DC3 control codes. Third bit from the left dictates what happens in that regard. From what I read, I think DC1/DC3 is Xon/Xoff and is used when transfering from PC to Fanuc (Tx) and DC2/DC4 is used when receiving from Fanuc to PC (Rx). Is that right? If so, how are they used? I thought it would mean that when the controller is ready to receive the program it sends a Xon signal (DC1) and when the PC is done sending the program, it sends a Xoff signal (DC3) but I might be completely wrong.
    Obviously from my 312 parameter, control codes are off which would mean the Xon/Xoff handshake is not used. However, I am still able to transfer programs via DNC software (although I have to send it twice for it to work). Is it vital to use the Xon/Xoff handshake? These parameters have been used and unchanged on our machine for over 10 years without issue. I have only started getting this issue where I need to send twice for it to work after I had to change the hard drive in the PC that's used for DNC. I would rather not need to flip the parameter write switch on and flip that bit to 0 if I don't have to.
    Does anyone have any insight on the behavior of control codes and how necessary they are?
    Also, does anyone have a Fanuc 6M maintenance manual in PDF or for sale? I have been using a 6T manual which is pretty much identical when it comes to DNC parameters but I would like to have a 6M if I ever run into more problems in the future.
    Thank you very much for reading and I am looking forward to hearing from you guys.
    May 2012
    Default Re: Need help with Fanuc 6M DNC parameters
    These control codes are used in the drip-feed mode when you send a large program to your controller.
    AGG Software. DNC Precision and CNC Syntax Editor software.
    Member machinehop5's Avatar
    Aug 2009
    Quote Originally Posted by samysnes View Post
    ...then its a PC issue not the CNC.
    Dec 2020
    Quote Originally Posted by machinehop5 View Post
    I figured as much but honestly, the PC hasn't changed either. Same XP installation, same DNC software, same settings. It's just very strange. I basically cloned the previous hard drive. I'll have to ask the operator if they changed a setting unknowingly.
    Dec 2020
    Quote Originally Posted by HDowns View Post
    So if our programs are small enough to fit entirely in the controller's memory, it wouldn't matter if that bit was 1 or 0?
