Wiring up a Dyn2 drive, pr. DMM's schematics
Results 1 to 4 of 4
Thread: Wiring up a Dyn2 drive, pr. DMM's schematics
    Member EddySPalm's Avatar
    Feb 2021
    Default Wiring up a Dyn2 drive, pr. DMM's schematics
    I am looking for inspiration as to how people on here have wired the two capacitors needed pr DMM's wiring diagram for the DYN 2's. just trying to get a clean setup and a safe mounting for the two circular capacitors.
    I attached the wiring diagram for anyone wanting to chip in even if they don't have the same set-up
    Attached Files Attached Files
    Feb 2021
    Default Re: Wiring up a Dyn2 drive, pr. DMM's schematics
    Dang, I was going to post this in the DMM section,not the EMCO section.
    Dec 2013
    I moved the thread to the DMM forum
    Capacitor mounting brackets are available, you only need to choose the proper size, or you could just make your own
    https://www.alliedelec.com/passive-a...ting-brackets/
    Jim Dawson
    Sandy, Oregon, USA
    May 2006
    saskatoon
    Quote Originally Posted by Jim Dawson View Post
    Thank You ! Will 3d print some for my box.
