Dmm Servo Spindle Setup Mach 3 - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 19 of 19
Thread: Dmm Servo Spindle Setup Mach 3
  1. #13
    Jan 2005
    Default Re: Dmm Servo Spindle Setup Mach 3
    Quote Originally Posted by Jim Dawson View Post
    The minimum step count / rev is 500 (Gear Number), so at the max speed of 3000 RPM (50 rev/sec) would be 25,000 steps/sec. Given the limitations of Mach3, new firmware might be a good plan. It's my understanding that Mach3 is good for 25K to 100K steps/sec depending on your computer.
    It has nothing to do with Mach3 when you are using a SmoothStepper even with a UC100 he can have a 100K SmoothStepper he can be set up to 4Mhz so does not need any firmware changed to get the max from his motor
    Attached Thumbnails Attached Thumbnails Dmm Servo Spindle Setup Mach 3-step-rate-4mhz-png
    Mactec54
  2. #14
    Jan 2005
    I stand corrected. You are correct. I misunderstood the manual.
    I've never actually tried to run one of DMM servos with Mach3. The only step & direction install I have done was using a high speed motion controller, good for 3MHz step output, so no problems. All of the others were analog control.
    The Smooth Stepper he is using is good for 4MHz so he will have not problem with any speed of his motor
    Mactec54
  3. #15
    Jan 2005
    I think that depends on which firmware rev. you have, the newer systems are 500 minimum. All of the ones that I have bought in the last 1.5 years have been 500 minimum.
    They have always been 500 from day one
    Mactec54
  4. #16
    Sep 2009
    Have you read through the smoothstepper documentation. It looks pretty straight forward and step by step. https://warp9td.com/index.php/gettin...epper-and-mach
    The other thing is you will need to set the DMM software to step and direction, and probably be good idea to set the gear number to 500 to net 2000 steps per rev.
    What DMM servo are you running there is a 3000 and 5000 rpm version rated at 750 watt?
  5. #17
    Jan 2005
    Quote Originally Posted by HCE View Post
    Most usually use the 1.8Kw motor which is 3000 max anything below 1Kw would not be much good as a spindle motor
    Mactec54
  6. #18
    Dec 2016
    Did you end up getting this sorted out? Im running an almost identical setup and might be able to shed some light on settings
  7. #19
    Jan 2005
    Quote Originally Posted by Danno11 View Post
    It is always good to post what you have done, even if it is a different setup there will be someone that it will help or give them and idea of where / how to start
    Mactec54
