Was looking into possibly getting the DYN4/400w 200v kit for my homemade CNC router and wanted to know a little more information on the voltage.
The drivers say they can handle 110-240VAC. If 110/120v is used on the drivers instead of 220/240v, will the motors still operate normally, just at a higher amperage compared to 240v?
Reason I'm asking is because I do not have 220/240v in the location where I keep my CNC router and wanted to stick with what was already in the area.
- So Far I've managed to Blow up 3 DYN4 drives - Please Critique my wiring..... HELP!!
- Anyone with experience from DYN4 drives and LinuxCNC?
- DMM Tech DYN4 cnc servo drives motors cables I/O boards full 3 axis system - No Longer Available
- Need Help!- Low Voltage vs High Voltage Stepper motors?
- Just IN- Provide controllers,drives,servo motors,stepper motors,electronic parts from China
Ok. So that's not bad at all. I had calculated the max speed (@3000rpm) to roughly 500ipm, and knew I would never be able to get that on my home machine.
I was not expecting to go over 1000rpm on the servo if and when I got it and installed on the system. So if the rpm is reduced and does not pull anymore than the other rated specs, I am 100% fine with that.
Doesn't running on 120V require double the amps?
UCCNC 2017 Screenset
I know if I never go above the rated amps (Which is 2.8A on the Dyna4 at 200v...Didn't look at the DYNA2 though.), you will never do more than at most 5A (Because the amps required is a somewhat linear scale. Actually comes out to 4.4A). Now, if I went above the rated amps, that is getting into some pretty high amperage territory... A little over 14A a piece.
But I do have a feeling that it would rarely if ever go over the rated amps if you stay below the rated speed of the motor. The reason I say this is because of a couple reasons. Since the torque required for my machine is more than 20% below the rated torque, I should never (knock on wood) go over that, in which case I am limited to speed to stay below the amp limit. Since I do not plan on going over 1000rpm with maybe a max of 1200-1300rpm for rapids only, I will never get close to the rpm limit as well. So in theory, I would never hit anywhere near 5A running the motor (The rated amps stated above) and for sure will never go over the rated amps into the max amp range. So yes, I can get by with running all 3 of the motor's on 120v supply and actually run the machine on a 10A breaker if I wanted to, never going above 1500rpm, let alone the 20A breaker that the cnc router is connected to.
If the above does not hold true though and I do start tripping the breaker running all 3, I might have to bite the bullet and convert the 120v outlet to a 240v outlet, and change the breaker from 120v>240v. But I didn't want to do that because I would also have to get a transformer to take the voltage from that 240 to something more reasonable (Around 200-210v).
Yes, be careful with the 240V. I first tested my DYN4 with a 245V outlet, and it blew immediately. DMM repaired it, but I haven't had a chance to test it again.
DMM sent me a white paper, and recommended a Line Reactor.
I'll probably use both a transformer and Line Reactor.
Look at the spec's for the motors you have, and look at the Peak Current for the voltage you are using, the Drive amps go higher as the supply voltage gets lower
Also check there spec's for the input power supply requirement's, they list 50A and 60A breakers for more than ( 1 ) Drive input Power supply, that is why I said 20A is normally ok for up to 3 drives with small motors, this depends on what voltage you are going to run with though
Mactec54
So, I think I am going to change to the DYN2 drives with a 750 motor. Honestly don't know if I want to run the DYN4 servo's at 120v. Was going to use either a 1000w or 1500w toroidal 70v power supply to power the 3 motor's. 14A on the 1000w and 22A on the 1500w.In the opinion of the member's here, if I go this route, should I get the 1000w or 1500w?
Also, with the 70v, I am hoping to get the most out of the motor. And in the future, when and if I decide to install 220/240v in the home shop, I can buy the DYN4 drivers (As well as the cables) and be plug and play with the current setup.
The RPM will be lower with the 750w motor when using 70v a 1000w 20amp toroidal power supply is enough you want to go for the next slightly lower voltage toroidal as I have found the 70v units will output around 72v but if this is a regulated 70volts then you should be good otherwise get a lower voltage like 68V make sure the output has 2 caps to filter the Dc ripple, Dmm will give you the size requirement for this
Mactec54
True on all accounts. As long as the RPM isn't lower than 1000-1500 RPM, it will work well for what I need. Unless I completely re-design my whole machine, I don't think I will be maxing out the RPM at the moment.
The toroidal PSU I was going to get was this one:
PS-10N70 - 1000W 70V Power Supply - AnTek Products Corp
If you think I should tone it down to 68V, I can get this one, though the drivers do support up to 80V:
PS-10N68 - 1000W 68V Power Supply - AnTek Products Corp
I have run the Dyna2 up to max voltage, but it is not a good Idea as if you get a surge and it goes over it is not worth the extra to do a repair, as long as the 70v Dc unit can be maintain the 70v supply then you won't have any problems
I have the same supplies and they run a little high, but that could be also my supply voltage is high also, so check your Ac supply voltage to see what you have
This is how I normally do the Dyna 2 Package
Mactec54
How about ATO-BLDC-150030, this is 1.5 kW?
