Brand new DYN4 400W set - goes in Overcurrent fault as soon as motor is connected - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: Brand new DYN4 400W set - goes in Overcurrent fault as soon as motor is connected
  1. #21
    Default Re: Brand new DYN4 400W set - goes in Overcurrent fault as soon as motor is connected
    Hello,
    I'm trying to wire up 2 of the same DYN4 400w 200v (lathe setup). Most people are telling me just to wire it up for 120vac. I've got access to 220vac just as easily.
    So, I have 2 questions:
    1. Which voltage do you guys recommend (and why)?
    2. Which magnetic contactor should I use for 120vac or 220vac?
    From what I read I need my model requires 1 - 10a 120vac (DIN mount in my case) magnetic contactor per controller. Can anyone recommend a part # for me?
    Also, apparently the noise filters are "optional" when going with 120v but I already purchased a couple along with a line reactor. I prefer to go with "better to be safe, than sorry".
    I have no idea why I'm having such a hard time with this - ugh!
    I greatly appreciate any info/advice.
    Cheers!
    -Sam
  2. #22
    Dec 2013
    If you are asking only about the contactor, there are 3 parameters to concider. Switching voltage, switching current, and coil voltage. Most contactors are rated at a minimum of 250V, switching current is stated as is the coil voltage. The switching voltage and current need to be compatible with the drive, the coil voltage needs to be compatible with your control voltage.
    An example of contactors that would work.
    https://www.automationdirect.com/adc..._-z-_overloads
    Don't forget to add the proper circuit breakers ahead of the contactor(s) per the DMM installation instructions.
    Jim Dawson
    Sandy, Oregon, USA
  3. #23
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by samtheclip View Post
    Hello,
    Cheers!
    -Sam
    You need the power filters no matter what voltage you use
    You only need ( 1 ) contactor as long as it can handle the current for the ( 2 ) drives
    Either voltage will work 240v is always going to be better if you have it
    Mactec54
