CNC Parts Bargins in Taiwan?
Page 1 of 3 123 LastLast
Results 1 to 12 of 25
Thread: CNC Parts Bargins in Taiwan?
    Gold Member Mr.Chips's Avatar
    Sep 2003
    Default CNC Parts Bargins in Taiwan?
    I will be going to Taiwan in about a week and will be there for a month. I was wondering of anyone knows of a source of bargains there in the areas of:
    Servo motors
    THK Bearings and Rails
    Power Supply
    Controllers ( probably should buy controllers here for warranties sake)
    Am planning a moving gantry that has a work area of 24” X 48”, and will be cutting wood and aluminum.
    What would be an advisable size for the Motors, THK Bearings and Power supply.
    Thanks,
    Hager Hay
    Apr 2004
    United Kingdom
    Hi:
    I am wondering if you will be in Taipei or North Taiwan. There is exactly a sweep shop of the parts you mentioning in North Taiwan.
    Unfortunately I could not translate the address from Chinese to English properly, the shop is behind the headquarter of EVA Air in TaoYuan.
    The address in Chinese is : 桃縣龜山鄉民生北路一段445號,研碩企業社
    Hope you could read chinese in your computer or you could get a GPS from the electronics streets in Taipei and I could give you the GPS location.
    I am in Taiwan working in CKS airport, TaoYuan. You may contact me throught e-mail or mobile: 0926311291. If I have time, I could give you a lift to there.
    Best Regards
    Tom
    calkai@hotmail.com
    Sep 2003
    Tom
    I am still in the US my wife and I will leave next week. My wife translated the address for me and she knows the area, there family used to live in Tao Yuan.
    What is a sweep shop?
    Hope I can find some goodies at a good price over there.
    Thanks Tom
    Hager Hay
    Apr 2004
    United Kingdom
    Hi:
    Sorry for my wrong vocabulary. It could be said as the factory equipment outlet selling the clearance stock of THK, NSK, Pacific, SANYO.JAPANSERVO and so on. Some are brand new, some are used.
    桃縣龜山鄉民生北路一段445號.南崁交流道長榮航空大樓正後方.
    研碩企業社.
    0910155897.(03)3118516. Mr. Lin
    Sep 2003
    This sounds pretty promising, I will for sure check this out when I am there.
    Have you or are you bilding a CNC? I have a movable table CNC completed except for the wiring. But won't finish it until I return from Taiwan in November.
    Tom
    Registered happytriger2000's Avatar
    Nov 2004
    currently in UK
    Halo,
    are you guys from Taiwan?
    Freeman
  7. #7
    Sep 2003
    My wife is. We were there for a month visiting family and friends. An I purchased some linear bearings and ball screws from a seller of surplus supplies like this.
    Regards
    Hager
  8. #8
    Nov 2004
    currently in UK
    Halo Mr.Chips, Im Freeman, Im from Taiwan and also a British citizen.
    Im building a cnc machine aswell and in 2 days time I will leave UK to Taiwan, and will start buying parts in taiwan. Im a Product Design Student and very interested in CNC machines. So far I have ordered 3 Geckdrives G320, and the rest will be built in my fathers factory...
    well nice to meet you
    Freeman
  9. #9
    Sep 2003
    I'v heard good things about the Geco's they should work well for you.
    I met a fellow, Tom in Taiwan that is also interested in CNC's look earlier in this thread for his phone no. He helped my a lot. He also went to school in the UK.
    And it's really good to have a Dad that has a factory to take advantage of. Ha Ha
    Do you have a plan yet, would be interested in seeing it.
    Regards
    Hager
  10. #10
    Nov 2004
    currently in UK
    At the moment Im trying to build a controller same as this: 'http://www.homecnc.info/servomotor.htm', but my electronis is not very good, therefore need more support from Electronics people..ha ha then the hardware I will build it in Taiwan.
    There's a wiring diagram of the controller in pdf, still trying to figure out how to connect all those parts....
    Freeman
  11. #11
    Gold Member
    Oct 2004
    you know, you could bring enough home for the rest of the class, buddy ol pal
    if not then you get this
    -Allen
  12. #12
    Sep 2003
    Freeman
    Well CNCZone is the place for the expertise in just about any area. Just go to the forum that has been set up for your particular need and ask away.
    You might post a brief sentence of your goals then ask one or two very focused questions, that way it won’t seem overwhelming to answer.
    I’m with you electronics is my weak point, I can follow a simple point to point schematic if it is well laid out but if it is incomplete because everyone knows that and it was too simple to illustrate, then I’m lost.
    What do you plan to make, when you get it running? I am interested in making an all wood pendulum clock.
    Later
    Hager
