30 amps seems sufficient to run your machine and perhaps a small spindle. You need to estimate its power consumption at maximum draw, plus a little overhead for safety's sake. But if you want an ATC, those usually require an air compressor, which would require more power, depending on its capacity. And a vacuum pump capable of holding that panel down will also have considerable power needs of its own. But I doubt you'd want to run all these devices on a single 50 amp circuit. More likely, the compressor will want a circuit of its own, and so will the vacuum pump. These should be sized to the machines you decide on - enough to give them more power than the nameplates say they need, but not so much more that the circuit breakers won't click off in event of a serious overload. Ask your electrician if there's room in your existing panel and enough power in the service for a couple more heavy circuits.
