Mounting of chuck to this type of planetary gearbox with stepper motor
Hi everyone, here looking to build a 4th axis for my cnc machine, has anyone used this type of system, the only way I can see to keep the chuck on the output shaft is used a screw, thoughts on it, thanks. https://www.omc-stepperonline.com/ne...s22-2804s-hg50
Re: Mounting of chuck to this type of planetary gearbox with stepper motor
ideally you'd use the key and a matching keyway, but I think a screw would be OK.
The specs say that the lash is 1.6 degrees, which is quite high for a fourth axis. Additionally you are relying on the bearings in the gearbox to support the chuck.
All-in-all that will very much limit the work you do to the lightest possible parts.
I have used an Atalanta Drives servo reducer. It has a lash of <2 arc min and a rated torque of 130Nm, and a max torque of over 400Nm, but its much bigger.
For size comparison the chuck pictured is 100mm in diameter.
well my fourth axis is about 15kg....so probably to big for your machine. The worm drive, if I bought brand new is over $1000USD.
I bought it off Ebay for much less than that.
Sir,
I thank you, I will be mounting it on a 6" by 1" by 5' hollow section aluminum, which can be changed if it isn't adequate, I will looked to order it, better to have such a unit and know that it can work then to get something that I maybe a trial and error, will be cutting aluminum and wooden pieces, may have to get a nema 34 stepper motor to turn it instead of nema 23 which was in the original plans.
from personal experience it is a very solid piece of gear. I have driven it with a 750w Delta B2 servo (pictured).
Originally I had a 23 size stepper on a 10:1 planetary to drive it, but that meant the fourth axis would only turn at 10 rpm. Many of my four axis toolpaths have many revolutions,
hundreds at least, and they take forever at 10 rpm. With the servo, it does 3000rpm, so the fourth axis now does 150rpm, which is much better, but I sure don't want it to go any
slower.
I'm building a fifth axis and it has a 6.75:1 reduction, <1 arc min lash, 70Nm (rated). It too has another 750W Delta B2 servo and can do 444rpm....so that a real step in the right
direction for those long continuous rotation toolpaths.
