Originally Posted by
peteeng
Hi Dan - I have made 12V systems in the hope of running demos in trade shows with a car battery but 12V was atrocious totally unworkable. I've made a few with 24V and they have worked fine, one with all 48V and its was fine. The latest is 48V/24V and it works fine on the bench have to marry it to a machine in the next week to really know. Its sister machine is 24V and its great so the 48V will be a bonus... My main reason for the dual voltage is the brake on the Z axis is 24V. I used to use gas struts, but the brake is so much easier and betterer...
But I doubt 24V is half the torque of a 48V. Torque has to do with current not volts. But you should be able to get torque curves from the supplier. I did a quick look at stepperonline and found this one 24V-48V comparison. Peter
re Z weight - a 5mm pitch screw will provide over 300kg of force at slow speed so if your Z is over that weight then your in trouble. Its also typical to set steppers to 50% amps when stationary this may not be the correct setting for the Z axis. So at 500rpm you have about 150kg of force available to you... 500rpm is 2500mm/min which is quite fast for a hobby Z axis.... So usually the z axis holding is not an issue. Falling when no power is an issue so balancing or braking is recommended...
