All of them should be sufficient for light work, but in all honesty all of them are weak.
What kind of equipment have you got to work with?
Can you process steel?
Best and cheapest would be to buy a steel or an aluminum square pipe for the spindle box. Steel are readily available and aluminum ones go up to 200x100x5mm, 500m length costs here about 40EUR. 5mm ain't much so you'd need to strengthen one side with a plate. Steel would be enough on its own.
Need more data.
