Hi Adam - If you want an economy one box G540 equivalent heres one. I've used three of these and they have been reliable and easy to set up. I use a UC100 with them....
https://www.oyostepper.com/goods-120...per-Motor.html Peter
Yes it is. Expense need be put in perspective though.That's getting to be an expensive Hobby...
as a ballpark consider:
Mach4 Hobby license $200
ESS motion controller $190
Own built breakout board $100
Ex Lease PC $300
TOTAL $790.
I've been using this combination for seven years, and plan on doing so for some years yet, so lets say $100/year.
My new build mill, about a year old currently, cost about $20,000, in parts, materials , machining services etc. Lets assume I use it over twenty years,
then the machine cost is something like $1000/year. It rather puts the Mach4Hobby/ESS/BoB/PC cost into second place.
The next question is software. I already use Fusion 360, and have done for several years. I'm not saying its the best, or the cheapest, but I do believe its the best
value for money CAD/CAM solution available at $500/year. I use Fusion 360 daily for work purposes, so I have little concern that I make on the deal overall.
Now I find myself questioning whether I will use 4th and potentially a 5th axis enough to justify another $1600/year. In researching the competing
software I find that all those whom offer 4th and 5th axis are right up there in terms of price, so while I initially though $1600/year was exorbitant
I have come to realise it is in fact competitive. So the question is whether I use it enough, and can make money with the Machining Extensions.
Autodesk have offered a generous discount, so I think I will try it. That will give me a year to establish whether its worth it or not.
Craig
G540, Rack and Pinion Drives-X/Y axis, 1/2-Ball Screw-Z Axis w/THK HSR 25 Linear Slides, Steppers KL23H2100-35-4B, Power Supply-KL-600-48
