Pump/Blower size for DIY Vacuum Table. (2500 mm x 510 mm)
Hello,
i hope someone can help me out.
I need to buid a vacuum table that i want to use to cut boards of a size of 2500 mm x 510 mm. Important note: Cuts will be done only on the top, so no through cuts, also the board size will not change, it will still be 2500 x 510 mm after the milling/routing is done. I hope you can help me out with that. I dont want to buy an oversized pump/blower and the table will be not used for anything else but just the 2500mm x 510mm boards.
