Originally Posted by
mactec54
Machine Coordinates is once you home the machine that is the machine Coordinate
Work coordinate is your G54 X---- Y---- Positions
Once you home your machine, these axis Home positions are the machine Coordinates X, Y and Z
Once you Home all your axis, you can then set the G54 X----- Y------ work Offset positions then your G43 Z axis Tool height Offset
What does Offset mean, this means you have set your work and Tool from the Homed Machine Coordinates some snips that may make this a little more clearer as to how it works
