I would expect that homing is all that should be required. Something you would do on any power up.
Hello guys, New here. Just bought a used AVID cnc router with clearpath/technik servos. The machine was jogged xyz during demo, was disassembled and had to move and transport to another location.
Now that I am re-assembling it and throwing the x-axis beam back onto the servo drives, anything I need to be aware of? Alignment, pre power-on checklist?
Both servos had been slid to another location independently during cleaning and transport (unpowered/disconnected).
Before I power on and do anything, My fear is that the servos may go in random directions, mostly due to the lack of my knowledge of not having ran a cnc like this before.
Any tips or suggestions for power on? Will the servos try to go back to their initial position? or do I manually home everything after tramming? The machine is using mach 4 and has crew 9.
Thanks in advance!
Mike
- Need Help!- Machine moved before received the arc OK signal
- Need Help!- Moved machine now it will not work. Mycenter 4 with Yasnac I80 control
- Moved a machine and now getting poor tool life!! Help!!
- Need Help!- The xyz axis of the machine can be moved only when we press the OT key
- Machine still moved in X-axis after E-button pushed.
Jim Dawson
Sandy, Oregon, USA
In this case, power up the machine with the motors off the machine, or with the pinions disengaged from the gear racks.Before I power on and do anything, My fear is that the servos may go in random directions, mostly due to the lack of my knowledge of not having ran a cnc like this before.
UCCNC 2017 Screenset
