Need Help! Lines on circle
Results 1 to 3 of 3
Thread: Lines on circle
    Member Alokjha's Avatar
    Jan 2022
    Default Lines on circle
    I build a cnc wood router machine with leadshine servo motor with plenetry gear box and NK105G2 controller.
    My problem is when i cut circle there is a line which is tool entering mark but exactly oppiste the tool entering mark there is one more line, which is not smooth. Please help me to solve this problem
    Jan 2008
    Ca
    Default Re: Lines on circle
    Sounds like a backlash issue?
    My Build: http://www.cnczone.com/forums/diy-cnc_router_table_machines/113711-my_build_-_many_thanks.html
    Jan 2022
    Quote Originally Posted by Mogal View Post
    Sir thanks for the reply
    When i changed servo motor with stepper circle cutting is fine but with servo motor lines comes
Lines on circle
Lines on circle
