I would double and triple check all of the wiring from the controller to the drive and from the drive to the motor itself.
I suspect a loose connection between the controller and the drive on the misbehaving channel, specifically for the direction signal. Make sure to check both ends of the wires and that all ground connecting are secure too.
Thanks, John Z
Sent from my SM-G991U using Tapatalk
