My first machine I used separate 5 v I but won't do it again.
The other advantage is it gives you 100% isolation between 5v logic and 24v field power sections but if you want to use a MPG, you have to common the 5v and 24v grounds so there is no point as it breaks the isolation.
So you are just left with extra cards possibly needing the extra power
