Z axis height calculation
Results 1 to 4 of 4
Thread: Z axis height calculation
    Mar 2015
    Default Z axis height calculation
    Hi when designing your machine in cad and calculating z axis height do I measure from the bottom of the collet to the top of the spoil board or from the end of the drill bit to the top of the spoil board?
    Also 200-250mm isn't too much is it?
    Thank you
    Dec 2013
    Default Re: Z axis height calculation
    I would make the bottom position with the collet touching the spoil board. The top position would be the maximum material thickness + the longest tool you will use + another 20 mm or so.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2015
    Quote Originally Posted by Jim Dawson View Post
    Thank you
    Member routalot's Avatar
    Dec 2003
    200 mm is a lot of travel.Do you really need it?The amount of flex in the machine increases as you increase the Z axis as does the possibility of the gantry flexing since the drive is normally imposed at the base.I suggest you draw the spindle and backplate with a tool in place to see what the limitations will be as you can't get too close to a vertical surface that extends further up than the length of the tool.
