Originally Posted by
JayneV
Hi Mactec,
Thank you for the attachments. Most of the Nema 23 motor shafts seem to come with a flat on the shaft instead of a key slot (I’ll do some more searching). Assuming the motor pulley is experiencing the same loads as the ballscrew pulley (same size pulleys), would I be correct in saying that both pulleys should use the same method of securing to the shaft?
Would you use a taper lock like the one in the attached image on a shaft without a key? I don’t want to be machining the motor shafts and it seems pointless to use a key on the ballscrew and not on the motor, if I am understanding correctly.
