Need Help! Cnc router electronics - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Thread: Cnc router electronics
  1. #21
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: Cnc router electronics
    Hi GoCe - Use proper round cars and matching round rail. Not commercial tubing, Won't work. Linear rail is hardened and ground to a specification. The car balls will gall the unhardened steel or aluminium tube. Peter
  2. #22
    Jun 2010
    what you think about SBR16UU linear bearing block on steel/aluminum tubing, can it work??
    Of course it will 'work'.
    Those hardened steel balls will work lovely grooves into the soft steel or aluminium tubes. After the first couple of passes there will be no more drag at all. Could be a little slop and rattle of course.
    Cheers
    Roger
    PS: the above 'approval' is not meant to be taken seriously.
