I assume that if a steel framed CNC Router, with machined surfaces, is to be painted, that the area under the linear rails is left naked,as it were, as the paint would make re-aligning the rails again difficult?
If so, does one used anything under the rails to stop rust?
Steve
- New Machine Build- Custom steel framed cnc router for wood and aluminum
- New Machine Build- Aluminium framed FEA optimized CNC router
- New Machine Build- ScratchPad - DIY Steel Framed 3x3 Router
- 1st build: Bright orange steel framed router
- long term stability of wood framed router
