Metal (iron based) machining requires far slower cutting speeds (end mill rpm) and far higher machine stiffness. Up to a million pounds per inch of deflection. High low speed spindle torque also.
So you can’t cut metal with a wood router.
It will chatter and bounce all over the place moments before the bit is destroyed.
