David A's Benchtop CNC Version 2 - Page 6
Page 6 of 6 FirstFirst ... 3456
Results 101 to 103 of 103
Thread: David A's Benchtop CNC Version 2
  1. #101
    Member davida1234's Avatar
    Oct 2009
    Default Re: David A's Benchtop CNC Version 2
    VACUUM HOLDING SET INSTALLATION:
    Machine bed already contains all the channels and holes for
    vacuum holding so just a manifold needs to be installed:
    David A's Benchtop CNC Version 2-exp-vac-1-jpg
    Manifold will be installed in this area under the machine bed:
    David A's Benchtop CNC Version 2-exp-vac-2-color-2-jpg
    Screw on the manifold to the underside:
    David A's Benchtop CNC Version 2-exp-vac-3-color-jpg
    Attach the standard Schedule 40 elbow to the manifold.
    It can be oriented in any direction to match the vacuum pump location:
    David A's Benchtop CNC Version 2-exp-vac-4-color-jpg
    Overall layout of the vacuum holding system:
    David A's Benchtop CNC Version 2-exp-vac-5-color-jpg
    Vacuum holding set installation is finished.
    A single piece of 1/4" MDF sheet on top of the machine bed to be provided by customer.
    BryggaCNC.com
  2. #102
    Oct 2009
    bryggacnc website has been updated with the vacuum holding set page.
    BryggaCNC.com
  3. #103
    Oct 2009
    Hi guys,
    I will be out of the country for business for a while and won't be able to work on the machine during that time.
    I will be following CNC Zone on the computer, though.
    David
    BryggaCNC.com
