David A's Benchtop CNC Version 2 - Page 4
Page 4 of 6 FirstFirst 123456 LastLast
Results 61 to 80 of 101
Thread: David A's Benchtop CNC Version 2
  1. #61
    Member davida1234's Avatar
    Oct 2009
    Default Re: David A's Benchtop CNC Version 2
    Final step for completion of the basic machine hardware assembly:
    INSTALLATION OF LINEAR DRIVES:
    The machine uses rotating ball nuts:
    David A's Benchtop CNC Version 2-linear-drive-1-jpg
    Some specs for the drives:
    • Size: 12mm ball screw
    • Lead: 0.1575" per ball nut revolution
    • Suggested max RPM: 3,000
    • Max speed @ 3,000 RPM: 470 IPM
    • Rotational mass: 4.4 ounces (without bearings)
    • Rotational mass diameter: 1.1"
    • Belt reduction ratio: From 1:2 to 2:1
    • Reduction on the machine: 1:1 on X and Y axis. 1:1.25 on Z axis.
    • Motor size: NEMA 23
    BryggaCNC.com
  2. #62
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hi David - You got me excited there I thought you had "real" linear drives but then I looked them up and they are called linear motors...
    https://www.hiwin.us/products/linear-motors/
    Keep at it, Peter
  3. #63
    Oct 2009
    Hey Peter,
    I don't know what you want to call them. I guess every power source driven actuation is a "drive" and every single axis actuation is a "linear drive"?
    I would probably call a linear drive with all necessary gears, belts and supporting parts "drive line".
    BryggaCNC.com
  4. #64
    Oct 2009
    INSTALLATION OF Z-AXIS DRIVE:
    Remove the bridge on the Z-slide shafts:
    David A's Benchtop CNC Version 2-linear-drive-2-color-jpg
    The drive will be installed on those four standoffs:
    David A's Benchtop CNC Version 2-linear-drive-3-color_arrows-jpg
    Linear drive in place:
    David A's Benchtop CNC Version 2-linear-drive-4-color-arrows-jpg
    BryggaCNC.com
  5. #65
    Oct 2009
    With the motor installed:
    David A's Benchtop CNC Version 2-linear-drive-5-color-arrow-jpg
    Place the bridge over the ball screw and the shafts:
    David A's Benchtop CNC Version 2-linear-drive-6-color-arrow-jpg
    Z-axis linear drive installed:
    David A's Benchtop CNC Version 2-linear-drive-7-color-jpg
    BryggaCNC.com
  6. #66
    Jan 2005
    Quote Originally Posted by davida1234 View Post
    Hey Peter,
    What you have is a Ballscrew with a rotating nut, it still a Ballscrew with a driven Ballnut, it is not a linear drive
    Mactec54
  7. #67
    Oct 2009
    Thank you for the clarification, mactec.
    I would correct the header to "ball screw installation" above but the "edit" button is no longer there.
    BryggaCNC.com
  8. #68
    Jan 2005
    It does not really matter how it is called as it is still linear motion using a Ballscrew
    Mactec54
  9. #69
    Oct 2009
    INSTALLATION OF Y-AXIS BALL SCREW DRIVE:
    Turn the ball screw all the way down so that the one end sticks out just about an 1/8" at the ball nut cage:
    David A's Benchtop CNC Version 2-linear-drive-8-color-arrows-jpg
    Thread the other end of the ball screw through the eye of the big front brace:
    David A's Benchtop CNC Version 2-linear-drive-9-color-arrow-jpg
    All the way through at the other end, place the motor mount/ball nut cage between the gantry braces:
    David A's Benchtop CNC Version 2-linear-drive-10-color-arrows-jpg
    Motor mount/ball nut cage in place:
    David A's Benchtop CNC Version 2-linear-drive-11-color-jpg
    BryggaCNC.com
  10. #70
    Oct 2009
    With the motor mount in place, turn the ball screw all the way in towards the back
    until it sticks out about an inch over the back cap and clears the eye at the front cap:
    David A's Benchtop CNC Version 2-linear-drive-12-color-arrows-jpg
    David A's Benchtop CNC Version 2-linear-drive-13-color-arrow-jpg
    David A's Benchtop CNC Version 2-linear-drive-14-color-arrow-jpg
    Install the grommet into the eye of the front brace.
    Make sure it is seated all the way around:
    David A's Benchtop CNC Version 2-linear-drive-15-color-arrows-jpg
    Back out the ball screw until it goes through the grommet and clears it by about 1/8":
    David A's Benchtop CNC Version 2-linear-drive-16-color-arrow-jpg
    David A's Benchtop CNC Version 2-linear-drive-17-color-jpg
    BryggaCNC.com
  11. #71
    Oct 2009
    For particularly dusty environments, you can place two brush stubs at the front
    and rear of the carriage. They help to clear dust on the non-rotating ball screw:
    David A's Benchtop CNC Version 2-linear-drive-18-color-jpg
    Place and screw down the dust covers front and rear on the carriage:
    David A's Benchtop CNC Version 2-linear-drive-19-color-jpg
    Screw down the motor mount/ball nut cage with four screws:
    David A's Benchtop CNC Version 2-linear-drive-20-color-arrows-jpg
    Make sure the rear of the ball screw is placed into the back cap seat:
    David A's Benchtop CNC Version 2-linear-drive-22-color-jpg
    Place the clamp onto the screw and tighten down:
    David A's Benchtop CNC Version 2-linear-drive-23-color-arrows-jpg
    BryggaCNC.com
  12. #72
    Oct 2009
    Motor in place:
    David A's Benchtop CNC Version 2-linear-drive-24-color-arrow-jpg
    Wiring attached:
    David A's Benchtop CNC Version 2-linear-drive-25-jpg
    Installation of Y-axis ball screw/rotating ball nut is completed.
    Repeat on the A-axis:
    David A's Benchtop CNC Version 2-linear-drive-26-color-jpg
    BryggaCNC.com
  13. #73
    Oct 2009
    INSTALLATION OF X-AXIS BALL SCREW:
    Install a hex cap screw on the motor plate as shown, leaving
    a clearance of about 1/4" between the hex cap and the plate:
    David A's Benchtop CNC Version 2-linear-drive-27-color-jpg
    Push the hex cap/motor plate through the hole and slide to the right:
    David A's Benchtop CNC Version 2-linear-drive-28-color-jpg
    Once motor plate/ball nut is placed, install the two bottom screws and start
    tightening while making sure that the ball screw is centered with the grommet eye:
    David A's Benchtop CNC Version 2-linear-drive-29-color-jpg
    David A's Benchtop CNC Version 2-linear-drive-30-color-jpg
    Two bottom screws tightened down:
    David A's Benchtop CNC Version 2-linear-drive-31-color-jpg
    Tighten the hex cap screw behind the cross brace:
    David A's Benchtop CNC Version 2-linear-drive-32-color-jpg
    Install and tighten the support brace onto the motor plate:
    David A's Benchtop CNC Version 2-linear-drive-33-color-jpg
    BryggaCNC.com
  14. #74
    Oct 2009
    As with the other grommet eyes, back out the ball screw to clear the grommet
    eye, install the grommet and turn in the ball screw through the grommet:
    David A's Benchtop CNC Version 2-linear-drive-34-color-jpg
    David A's Benchtop CNC Version 2-linear-drive-35-color-jpg
    Place the other end of the ball screw onto the clamp pillow:
    David A's Benchtop CNC Version 2-linear-drive-36-color-jpg
    Place the clamp on the ball screw and tighten down:
    David A's Benchtop CNC Version 2-linear-drive-37-color-jpg
    BryggaCNC.com
  15. #75
    Oct 2009
    The installation of ball screws and the mechanical assembly of the machine is finished.
    This will be posted on the website as the base machine on which I am working right now.
    Next up will be all peripheral additions.
    Image of all ball screw arrangements (some drag chains omitted for clarity):
    David A's Benchtop CNC Version 2-linear-drive-38-gradient_color-jpg
    BryggaCNC.com
  16. #76
    Oct 2009
    Mechanically finished machine from the front:
    David A's Benchtop CNC Version 2-machine_front-jpg
    David A's Benchtop CNC Version 2-machine_front-gradient-jpg
    BryggaCNC.com
  17. #77
    Oct 2009
    The machine is mechanically finished and ready to accept all your electrics, electronics and peripherals.
    I also designed expansion sets like spindle cooling, cutting fluid or air, dust collection,
    vacuum holding, wiring, etc. which were specifically made for this machine.
    The following posts will show the installation of all the expansion sets.
    SPINDLE COOLING EXPANSION SET
    Spindle cooling set contains two 8-pipe radiators and fans,
    a 200 mL reservoir, a brushless mag-drive, 60 gph pump and hardware.
    This setup has been running for two years on my prototype machine without any problems.
    Parts for water cooled spindle set:
    David A's Benchtop CNC Version 2-exp-spindle-cooling-1-jpg
    Set will be mounted on the top plate of the X-carriage:
    David A's Benchtop CNC Version 2-exp-spindle-cooling-2-color-jpg
    Install one side with two screws as shown:
    David A's Benchtop CNC Version 2-exp-spindle-cooling-3-color-jpg
    Looking from the inside:
    David A's Benchtop CNC Version 2-exp-spindle-cooling-4-color-jpg
    BryggaCNC.com
  18. #78
    Oct 2009
    Install the second radiator/fan the same way on the other side:
    David A's Benchtop CNC Version 2-exp-spindle-cooling-5-color-jpg
    Install the reservoir bracket and the two standoffs:
    David A's Benchtop CNC Version 2-exp-spindle-cooling-6-color-jpg
    Place the reservoir on the standoffs and secure with a zip tie to the bracket:
    David A's Benchtop CNC Version 2-exp-spindle-cooling-7-color-jpg
    Slightly warm up the ends of the 1/4" hose to soften and connect the parts as shown.
    It is a bit tight but the hose will go over the nipples.
    On the prototype machine, it didn't need any clamps to stay on:
    David A's Benchtop CNC Version 2-exp-spindle-cooling-8-color-jpg
    THIS CONCLUDES THE INSTALLATION OF THE SPINDLE COOLANT SET.
    BryggaCNC.com
  19. #79
    Oct 2009
    WIRING EXPANSION SET:
    David A's Benchtop CNC Version 2-wiring-1-jpg
    Wiring set includes one junction box, three PNP sensors and all necessary signal and power wiring for
    4 servos, the sensors and associated connection wires connecting the machine to your controller.
    The Molex connector ends work with Teknic servos or the ends can be modified to fit other motors.
    Included OMKQN sensors do not require magnets and have been working good on the prototype machine.
    I could not measure any differences between them and the higher end sensors.
    David A's Benchtop CNC Version 2-wiring-1-arrows-jpg
    BryggaCNC.com
  20. #80
    Oct 2009
    Junction box will be installed on the back brace using these holes:
    David A's Benchtop CNC Version 2-exp-wiring-2-jpg
    J-box installed with the spacers.
    On top is a saddle for the reservoir to sit on:
    David A's Benchtop CNC Version 2-exp-wiring-3-color-jpg
    X-axis limit sensor will be installed onto the slot of the back brace:
    David A's Benchtop CNC Version 2-exp-wiring-4-color-jpg
    BryggaCNC.com
