Hello everyone My Cnc Router is having problem witth Z movew Some times ignore GCode and other move different distance of Mach 3 GCode Lest time G code says G00 Z-6 (mm)and the axis movement was to -13. What could be the cause of this failure? Thanks in advance ReneSimilar Threads:Need Help!- Z-Axis Motor Makes Clunking Noise little lost on G03 between Mach and PCNC 1100 Mach... Who makes a Cat 40 4 axis head? Who makes Big Mack Tool Holder? lost the link..Need Help!- Mach 3 lost is setting
View Tag Cloud
Forum Rules
