Need Help! AXIS stepper/servo motor requirements, want shared components from router to mini mil
Results 1 to 4 of 4
Thread: AXIS stepper/servo motor requirements, want shared components from router to mini mil
    Apr 2008
    Default AXIS stepper/servo motor requirements, want shared components from router to mini mil
    I am building both mini mills and router cnc machines and I want drive components interchangable between them. Is 3 nm a good driver for the axis' on a wood router? such as these:
    https://www.aliexpress.com/item/4000...archweb201603_
    Jan 2008
    Default Re: AXIS stepper/servo motor requirements, want shared components from router to mini
    Are you planning on swapping motors between machines?
    It will not be easy to mount and unmount motors and the associated wiring.
    I have shared drivers / control electronics / computer for a mill, lathe and router.
    Each machines has its own motors (all the same model steppers). I use an industrial 48pin connector to swap the connection for the drivers etc.
    7xCNC.com - CNC info for the minilathe (7x10, 7x12, 7x14, 7x16)
    Apr 2008
    Quote Originally Posted by pippin88 View Post
    I don't plan to swap the motors between machines, I'm simply taking from a spares and maintenance perspective.
    Is a nema 23 3nm sufficient for a router table? I know it's enough for my mini mill
    Mar 2003
    Shelby Township
    Depends on how big the machine is, and how fast you want it go.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
