New Machine Build 4x4 CNC Router build. 45hsr rails?
Results 1 to 2 of 2
Thread: 4x4 CNC Router build. 45hsr rails?
    Mar 2005
    Default 4x4 CNC Router build. 45hsr rails?
    I got a really good deal on 2 hsr45 rails with 2 bearings for each. I'm thinking about using them for my cnc router build , do you guys think this is a bad idea, they won't be used on the moving gantry only on the frame part.
    Any input would be greatly appreciated.
    Thanks Mike
    Jan 2008
    Default Re: 4x4 CNC Router build. 45hsr rails?
    They may have more friction / require more motor torque. Depends partly on the preload.
    I would happily use them for a router.
    (I would go and pay lots of $$ as they are overkill but you already said you got them cheap)
