If I were going to build a 4 axis machine to build rifle stocks I would start with about a 14x40, maybe a 15x50 metal lathe, add CNC with a Y axis. That would make an incredibly solid base. Use a Porter-Cable 7518 router motor, or any good Chinese spindle. Could even add a shaper head for roughing out the stock.
From your other posts I know you are a machinist and have machine tools. So modifying a lathe should be no problem for you.
