I've been using water soluble lathe coolant fluid mist on my router for alloy. Its awesome, but I definitely do notice the difference when I dilute it too much.
Wondering what other people use for a cost effective solution? I am thinking of making it a flush system as the mist is not recoverable and I have built the table that way.
Looking around at options I am seeing most fluids are $100 to $250 for 5L
What do you use?
Oh. I did try Jet A1 once (kerosine) it worked ok too but was steenky and slightly scary.
