New Machine Build DIY 5 axis CNC Router
Results 1 to 4 of 4
Thread: DIY 5 axis CNC Router
    Member Harshcarver's Avatar
    Mar 2019
    Default DIY 5 axis CNC Router
    I need your opinion on this. Planning to build this 5 axis CNC Router.
    This is rough concept.
    Attached Thumbnails Attached Thumbnails DIY 5 axis CNC Router-mini-5-axis_1-jpg   DIY 5 axis CNC Router-mini-5-axis-jpg
    Jan 2008
    Default Re: DIY 5 axis CNC Router
    Unsupported rails = cooked spaghetti. Floppy.
    Apr 2007
    u s a
    maybe look at a Haas UMC for some direction on design. they work well and seem to be similar to what you are looking for in movement. i'm not sure how important the horizonal configuration of the spindle is to your needs but the Haas might give you some design ideas. i would go with a square style linear rail opposed to the round rails. like the previous person said you are going to need support everywhere. i would think the rotary combo hanging out as shown will become a problem area pretty quickly. not to mention the weight factor of that part of the design when it comes to raising and lowering that end.
    Member routalot's Avatar
    Dec 2003
    What software do you plan to use for generating the programs?
