I've had a similar experience when a soldered connection to the motor became loose.I tracked it down and redid the soldering and it has been fine since.
Hello all, I hope this is the correct subforum to ask this:
Three different size and different brand motors are working fine on my build, but I have one NEMA 34 hybrid stepper motor and driver from Longs Motor that isn't: the motor makes a constant "alarm" style noise when it is energized. It functions correctly but it is loud and incessant! When I start the machine, it sounds off, stops briefly, and then continues as long as the driver is powered. Please help me troubleshoot this dang motor/driver.
Thanks for your help,
Tanner Frisby
Thank you for your response.
My particular resolution was to swap out the driver. The noise followed the driver, so a new driver fixed my problem. I have a hunch that something similar to your issue is occuring inside the driver. I have MUCH more torque with the new driver. I could see a faulty connection not always providing current to one of the phases and then snapping back into place at a rate in the audible frequency.
Alass, I don't know what the root problem was and it probably isn't worth investigating further. I got it fixed enough to move onto the next gremlin.
Possible solutions posted on other forums include the following: Change the microstepping rate, Substitute hardware to try to further isolate the issue.
