See if you're losing steps in Z by commanding a few moves and then a return to zero. Each move should complete before the next one is started, but if the Z axis isn't retracting to its clearance height that would account for it.
So out of the blue my z axis is not retracting fast enough to clear the cut before it goes to the next cut and its cutting my projects up. Ive cut this piece 20 times and all the sudden it starting doing this. Ive checked my steps. Ive checked my machine axis and my work axis. Ive checked my safe Z in vcarve. I am racking my brain trying to figure it out!
- Need Help!- LAser cutting machine makes a wave in a corner at the time of cutting
- Problem- axis not moving Only DRO moving on mach3 screen for cnc router 6040
- Trying to Square a Fully Disassembled X3, I have too many moving pieces...Help please
- Need Help!- My CNC router gets out of alignment when moving in X and Y at the same time
- Y-Axis Mexican Hat Wave?
