Trying to add rotory axis, need help.
Results 1 to 2 of 2
Thread: Trying to add rotory axis, need help.
    Mar 2006
    Default Trying to add rotory axis, need help.
    Howdy again! its been a while and Ive got a new obstacle Im trying to overcome. Im trying to add a rotary axis to my DIY machine, Let me give yall the rundown of what I have and what I am thinking and yall can help me from there.
    My 3 axis machine is using g540 / uc100 / mach 3 and currently has the "A" axis slaved to the "Y" stepper for dual lead screws on the Y axis. This obviously uses up all 4 outlets on the G540. I am very happy with the machines current performance and setup and am not looking to overhaul my motion control setup.
    I was poking around trying to see if it was going to be possible at all to achieve what I am wanting and someone had recommended to put this....
    https://czh-labs.com/czh-labs-din-ra...RoCtjAQAvD_BwE
    ... in between the uc100 and the g540. This would allow me to tap the pins before it gets to the g540 and I could add a single g250x or g251x driver for the rotary axis. I could then create a profile in mach just for the rotory in mach when I want to use it.
    Any ideas?
    Attached Thumbnails Attached Thumbnails Trying to add rotory axis, need help.-db25-jpg
    Member vger's Avatar
    Jan 2006
    Mexico
    Default Re: Trying to add rotory axis, need help.
    Yes that should allow you to tap off and isolate 2 pins for step and dir for the 4th axis, as well as tapping into an enable pin if used. Nice looking machine!
