- Motor/Stepper Cable Source
For a DIY plywood router build, ideally I would like to run 5 conductor shielded cable for all the moving axis steppers, 4 motor and 1 frame ground.
Best I can find is ~1.40/ft.
I'm looking for an inexpensive source for continuous flex cable 18AWG ideally. Where do you source inexpensive cable?
- You may not post replies
- You may not edit your posts
Forum Rules
