Losing steps on Z-axis BOTH ways..
Results 1 to 15 of 15
Thread: Losing steps on Z-axis BOTH ways..
    Default Losing steps on Z-axis BOTH ways..
    Hello,
    Have had my cnc complete for months and had run some programs with it, mainly engraving. The thing is, Z-axis seems to loose steps, either up or down..
    also slaved A-axis or X-axis (dual stepper X-axis) is missing steps causing the gantry do some twist. seems that Y-axis have not loose steps, or I dont only know it.
    Here is what I have tried so far
    1. Played with speed and acceleration of motors.
    2. Changed to shielded cable from motion controller to stepper driver
    3. playing with different kernel speeds and sherline pulse mode
    4. checked mechanical jams
    I wrote test code today for z axis and first it was slowly losing steps and dropping. Then I created another test code and it was slowly rising?????
    First code moved Z-axis down as Y and X wasn't moving and Z-axis up with X and Y axis also moving
    Second code moved Z-axis down with X and Y also moving and Z-axis up individually Y and X still.
    Do you have any thoughts or suggestions ?
    I have this chinese usb smoothstepper
    https://i.pinimg.com/originals/d8/ba...5d57b06a3b.jpg
    15A power supply 24v
    nema 23 motors
    tb6600 drivers
    May 2004
    Default Re: Losing steps on Z-axis BOTH ways..
    what's your backlash like?
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Drop the acceleration very low, and see if you still lose steps.
    UCCNC 2017 Screenset
    Hi, there is some backlash, but if I left mill running that test code which slowly looses steps and rises, it will raise without limit...
    I have already lowered it but will do some more testing with lower values.
    Mar 2003
    Shelby Township
    What values are you using for accel and velocity?
    Backlash has nothing to do with losing steps.
    Quote Originally Posted by ger21 View Post
    400mm/min velocity and acceleration 100mm's/sec
    Z-axis have 2mm pitch leadscrew
  7. #7
    Member awerby's Avatar
    Apr 2004
    24 volts is really low; it's surprising this works at all. Replace the power supply with one that puts out 36vdc and it will probably work better. Those drives are supposed to handle 42v, but that's probably something you don't want to push to the max.
  8. #8
    Quote Originally Posted by awerby View Post
    https://www.reprap-3d-printer.com/pr...-driver-tb6600
    This site recommends 12-24volt supply. those drivers worked good with 12 volt also, so I don't think thats the problem
  9. #9
    Apr 2004
    How much inductance do those motors have?
  10. #10
    Nov 2013
    those TB6600 IC's as used in your driver have a long and checkered history. A Gecko 540 would improve your experience.
    Craig
  11. #11
    https://www.ebay.com/itm/-German-Shi...r/272109517319
    Inductance: 3.5 mH/phase
  12. #12
    Jan 2008
    Optimal voltage for stepper with 3.5mH inductance is around 60 volts.
    Square root of inductance x 32 = optimal voltage
  13. #13
    Well well, back to this. Today run some test with 1/32 microstepping and every axis was losing steps, like 1mm. Then I set all drivers to 1/4 stepping and seems that I didn't loss any steps.. So far so good. Also ramped speed and acc up as I was not loosing steps and still seems that no lost steps. I'm still buying gecko at somepoint.
    Worth mentioning that I swap mach3 from laptop to my gaming pc and run tests with it. problem seemed to be with microstepping and drivers or simply USB motionboard is not fast enough for 32 microstepping.
    Hope this helps somebody.
  14. #14
    Sep 2005
    Its my understanding that the coarser setting like you did gives a stronger pulse. I think you found the solution.
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
  15. #15
    Jan 2008
    Some parallel ports are borderline on their voltage output and this can cause issues
