It's been a while from last post... any progress ?
Have not done much lately . trying to not spend extra with all the covid stuff going on .
So, have you thought how you are going to tighten the bolts holding the X axis cars after the X rails are mounted on the gantry?
I was thinking about it, and normally you would install the rails first so that you can properly align them and then slide the cars on individually and after that mount your Z axis to the cars. It looks like your cars are not threaded and will have to be bolted to the aluminum plate.
I may not understand, just thinking out loud.
Bob
Are those SYK motor mounts?
I can see you've welded some flat bar where you will mount your rails. I did a similar thing, so I know that they probably aren't very flat right now. It looks like you will weld them onto your gantry as well? What's your plan to machine those?
Diablo makes great blades. I used to use the Diablo Non-Ferrous blades quite a bit. I may have to try the ferrous one for myself. Cutting big steel with an angle grinder is alot of work, and band saws never seem to cut square. I'm amazed that you can cut half inch steel with a skill saw.
Is it expensive to get something like this heat treated?
Nice work.
Hi!
Still looking at this thread but no new updates so i'm calling You out @mactec54
How's Your machine ? Did You make any chips on it ?
