Hi All and good evening - Health Warning - Tramming can send you crazy! I pulled out a tramming fixture I made some time ago from some bits I had. I set it up and the spindle wasn't too bad. As soon as I tried to adjust it, it went AWOL!! Tried and tried but no luck really. I think the issue is that the spindle clamp uses one side to fix and the other side to fix and clamp the spindle. This two function side makes it tough to pull it down without changing its tram. So I adjusted the adaptor plate and tried some shims then gave up. So its close but was closer in the start! I'll have to address this and design a clamp that includes a tramming function... Peter
